fibreflex
Re: fibreflex
The strokers look the best in turners and the hesters in my opinion, the strokers I got off you , they are a bit of a problem to use on boards as really you need to have them on an expensive board really and either you have to drill 2 extra holes for the weird mounting points on these which you don’t fancy doing or drill an undrilled board which if you ever take the trucks off you’d have to drill an extra few holes in it for normal trucks
Re: fibreflex
Ahh I see you used some risers and a nut and bolt through them , I might try that , I’m only going to look at it 😂
punkboy wrote: Sun Jun 22, 2025 3:48 pm i made my own adaptors,if its just for display purposes then they are fine
Re: fibreflex
yes just use a couple of those rat nuts like on the old rails etc as they sit nearly flush on the riser then
Re: fibreflex
punkboy wrote: Sun Jun 22, 2025 11:01 pm yes just use a couple of those rat nuts like on the old rails etc as they sit nearly flush on the riser then
Re: fibreflex
few more,all original nos
